Vaughn MacKenzie
I am curious to find out approximately what percentage of guys have experienced an engine miss with their p-pump 12-valve. In particular a steady miss where it's one certain cylinder not putting out as much power as the others, resulting in a noticeable shudder at idle or under part load. It may miss at idle, at part load, at certain RPM, or all the above. . . but this poll is to focus on the steady single-cylinder miss problem guys often have.
Here's how to answer the poll:
If you only have the typical erratic cold-startup miss or have touchy/erratic GSK (quick stutter or bark) check "My 12-valve runs smoothly. "
If your miss doesn't fall under the description I gave above and is occasional, random (isn't any particular cylinder) or may have to do with a radical pump/injector setup then check the last option.
Please don't vote if your engine didn't come from the factory with a p-pump.
Thanks all,
Vaughn
Thanks all,
Vaughn
