Hello
My friend has a 94 dodge 12 valve CTD 4X4, the truck had a leaking rear main seal took it in and had the rear main seal replaced then the transmission lines go out replaced them. the truck starts fine runs but hesitates under load then stalls out.
the mechanic has said that the lift pump is moving fuel and they have flushed out the fuel lines and has now determined that the HP injection pump is bad. he says he hears something in the pump Now I have not been involved in the trouble shooting process. but i am curious as to if the infamous fuel shutdown solenoid might have something to do with it. or is there any other problim that i have not thought of ??
thank you
Chris
thank you
Chris
