Attached is a pic of the modifications needed to use the '94-'97
master/slave cylinder. The exact dimensions you will need to measure
as I forgot where I saved them, but it is pretty easy. Just measure
from the end of the rod to the center of the hole for accuracy. You
are going to be making 1 rod out of the two.
1. You will need a small flat screwdriver to slide down inside the
master cylinder to bend out of the way the spring clips that hold the
master rod in there.
2. Cut both master rods as marked and make sure you leave enough room
for your clutch switch to slide back and forth. I slid the clutch
switch all the way forward and marked that spot. I added 1/2" and cut
there. I cut the stock rod about 2" from the eyelet and then cut it to
fit later after I threaded it.
3. 3/8" thread both ends of the two rods. On the one with the clutch
switch, only thread to the mark you made (1/2")
4. Use a 3/8" coupling nut to attach then together. Because both ends
have the same thread (right hand) a jam nut is not needed. You can use
locktite if you want.
5. Pop back in to master cylinder. The spring clips will grab it
again. I did this after the master cylinder was installed in the
firewall for ease of installing the master cylinder. I used the foam
washer off the stock master cylinder for a tighter fit in the bracket
that bolts to the firewall.
6. Route the slave cylinder down to the bell housing and install. I
tiewrapped the line to other cables, etc. to keep it from rubbing on
anything.
7. Adjust the end of the rod to your liking. This will change where
the pedal sits in relation to the floor.
