Details here: TDR Privileges
I have a 12 valve cummins out of a komatsu back hoe and i also have an allison 545 trans what do i need to make them work the trans bolts to the motor what kind of flywheel or spacer do i need. please help
if your motor has the SAE#3 bellhousing, you need the 545 flex plate,centerhub adapter( to center the t/q converter) and the ring to bolt the t/q converter to the flex plate, the bolts to attach the flex plate/center hub to the crankshaft, and the bolts to attach the ring to the t/q converter and the flex plate. get the stuff from a truck wreckin` yard. if the flex plate is the same diameter as the current fly wheel, your starter should work, if not you may need the starter from the 545 set up. :-laf you will not use the flywheel that`s on the engine now.
