Archived 12 valve won't idle
Archived 3rd Gen Cummins Ticking/rattling/exhaust leak??????
Archived Please Help !!Need a NV4500 in S.L.C. Ut
Engine is hard to start (turns over many times) and idle is eratic with engine eventually quitting. Even when running it does not seem to have any power - it will die like a gasser if the clutch is let out.
Thanks, Barry
Is your fuel filter plugged? Lift pump bad? What is your fuel pressure? Sounds like you are not getting much fuel.
Is your idle too low? Minimum is 750 RPM with the AC on. 800 is better. Give it a little pedal to start it and see if that helps.
Fuel filter is new - it will start and run up to 1500-2000 rpm w/no load and I think i could get it out on the road but am not sure where when it will leave me. When you take foot off the pedal it will die. Last week it idle'd fine (about 800).
Thanks, Barry
