120 volt outlet troubles
Compass and map wrong
8.4AN Replacement
My 3500 Ram has a 120v outlet that shut off while being used. Probably slightly overloaded. Truck is not in battery saver mode and the 12v fuse seems good. Any other things I can check? Does it have a 120v fuse or breaker? And where is the inverter located? Thanks folks
I keep a tablet /phone charger plugged into mine and the other day it quit charging. I unplugged the charger and shut off the truck. When I restarted it came back on.
Mine died a couple months ago and 2000 miles. It’s not coming back without help. Guess I will try the dealer next week.
It a fuse and the inverter is located behind the plug. The panel will have to come off. Probably just a fuse, check that first. F38 30 Amp Pink Power Inverter 115V AC
