Oh, to add context: 27. 6" inches of water is a single PSI.
So even at the horrendous restriction of 27. 6", you're only dropping the pressure of the atmosphere (to the turbo) by a SINGLE PSI.
Of course, even this lone single psi may be enough to collapse a filter. If a BHAF has 144 sq in surface area, that 144LB of force on the filter-- probably enough to collapse it.
So you can get 1200 CFM with relative ease. You just pay a price in restriction (inches of water) and filtration efficiency.
Note that a BHAF is 99. 99% efficient (not sure at what micron) but the stock filter is "only" 99. 56% efficient. That extra efficiency is the main reason that the BHAF flows pretty poorly given its size.
BHAF are NOT designed for high flow, plain and simple. They are designed for long service life and high efficiency above all, while delivering ADEQUATE flow.
If you only need 400-600CFM, then a BHAF is perfect for you.
But at 1200CFM, you need a lot more radical steps.
