I got a chance to work on a motor today that is a little different. Differences are: No freeze plug in the back of the block..... hole is there but no plug. Block heater hole wasn't tapped. Not a storm block... . no second drain bung. Big main cap bolts..... looks like 14mm's. Block isn't inset machined for the oil pump... . odd! Aft oil supply bung in the drivers side of the block that you don't use is blank.
This short block was bought new, no rebuild.
Anyone know were this type comes from... ... . BTW, no block number they usually are under the pump.
Jim
Jim
