vastan
I am the original owner of a 1997 Dodge Ram 2500 with a 5.9 12V Cummins with 5 speed manual and 4x4. The truck has less than 130k miles on the odometer. About 4-5 years after taking delivery, I had to start lightly pressing in on the throttle to get the truck to start. Up until about 6 months ago, it would fire up every time with no issues. Now it only fires up when the engine is cold. If I try to start the truck immediately after driving it, the throttle pedal gets hard to push in and I am almost forced to push the throttle all the way in until the RPMs spike and a big cloud of smoke belches from the exhaust. This does not always work on the first try. Otherwise, the truck has no issues whatsoever once started and has plenty of power when pulling or just driving around town to the hardware store.
Over the past 2 years, I have replaced the following parts as either maintenance or to avoid future issues due to the age of the truck's original components.
However, I have never serviced the mechanical Bosch fuel pump or replaced the injectors. However, I doubt it is the injectors since the truck runs perfectly fine once started and has no problem starting when cold.
Any help in resolving this issue would be greatly appreciated.
Thanks,
- Fuel Shutoff Solenoid
- Installed fuel filter kit FFK9798
- Replaced fuel pre-filter screen, though original was clean and free of debris or deposits after over 20 years.
- Replaced turbo with ATS Aurora 4000 Turbo System since my boost was fading on the original Holset unit.
- Replaced the exhaust manifold with ATS Pulse Flow Exhaust Manifold Kit, 3-Piece
- Installed a MBRP 4" exhaust pipe with muffler.
Thanks,
