Template errors
  • Template public:thread_view: [E_USER_WARNING] Method canConvertThreadToRmsItem is not callable on the given object (SV\SearchImprovements\XF\Entity\ThreadCollab) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsReview is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsQuestion is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsFaq is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsEvent is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsLocation is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsCheckIn is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template :: [E_USER_WARNING] Method canViewRmsItems is not callable on the given object (SV\AdvancedBbCodesPack\XF\Entity\User) (src/XF/Template/Templater.php:1277)
Competition 12v tech Innovation
Competition 2006 DHRA Sportsman Class?
Competition Cranberry TWP Pennsylvania
I was able to successfully install ISB injectors in to my 12v motor, Small holes were drilled into the sides of the rigid fuel lines then, the ISB stems were welded to the lines, I haven't gotten fire yet but stay tuned, I think it will be the winning combination we've been looking for.
Quit messing around with more power stuff. I just about meessed my pants when you took me for a ride last time. Now do you really want that? :eek:
Green Machine said:
Well have you got the stems all welded back on yet?
How does it run?
Can I have a ride
it's studdering on the low end and I have a flat spot at the top end, there's some poping going on as well (everytime I floor it) I'll work w/ it.
Fletcher ... pls post when Nascar is going for the ride ... i'll head up your way. :-laf
Mark- just make sure you wear your flame retardant- flamed spandex with matching sweatband. Oh and will you be wearing you Grand PooBah headgear?
silver03 said:
What would be the advantage of running and IBS injector in a 12v.
For years, high performance pulling trucks have practiced intergrading
lateral feed, close loop, subordinate fueling sub systems to their package. This has been a limited information item that few would divulged. Two years ago at the Mason County fair, a renowned puller by the name of Leonard Orlando Oliver Peterson Sr. (Loops) shared this valued secret with me.
I started testing the application and discovered impressive torque/ fueling curves. As a matter of fact, during a 140mph interstate test, when my wheels finally hooked up, it lifted the front end off the ground. :eek:
Wow I need to learn more about the other engines. .
This system dumps fuel at a non governored rate at all times, and then the primary system privides actual control????
Forgive me as the only thing I can relate it too is import racing. . and old redneck stories about 80's fuel injection. :)
Tell me if i'm on it or not. Better yet, is there any literature about it?
Why go with ISB Injectors? Why not integrate HPOP injection... ... then you could use a tuner. your LOOP system could be infinitely adjustable as long as there is no adverse reaction to the angle of the dangle of the injection event.....
BManis said:
Im new to the whole diesel thing, just curious how did you work the spray pattern? or is that a stupid question?
I dissolve mineral tablets in my tank. So, polyoxides go un-detected.
Back in 1850, when that JD dude started stepping up and buffing the bottom plow, farmers could cut through that prairie sod much easer so, manure mixing became a stick free process. Once in a while, someone needs to be thrown from the helicopter to promote dialog exchange. Keep in mind, the blue whale just doesn't eat one big clam, it takes allot of krill to accomplish a healthy feeding. Just like with technology sharing, we become paradigm buccaneers by the accumulation of several little ideas. When, I first moved here from Vestmannaeyjar Iceland, people laughed at the way I caught Cod, now everyone's uses the same long lining lure.
“An Amish trained horse always returns back to the barn”
I thought dialogue promotion was the soul purpose of the banter section :)
It was late and I could barely see to read... .
A dedicated two stage sprayer could work though.
T/S don't let Fletcher fool ya this guy is on the cutting edge of Diesel teck.
I was over at his house yesterday afternoon. ( he walk's with his lamas from 10-12)
And he opened up his shop. And what do you know there were HONDA turbos all over the place. Some were welded to gether and some were plumbed inline to a HX-40 to this HUGE FRICKEN THING that looked like it came off of an army tank.
Fletcher was explaining that you need to stair steep the turbos for instant off the line boost. I asked Bill "how much boost you running now"
all he did was smile and say " a little more than 130 at the big end of the track"
crazy farmers any how.
I did get a sneak look at his nexts drag truck.
It was a 2002 Dodge ex cab long bed 4x4 bubble butt.
He said he would like to own the fastest 2 wheel drive street truck and 4x4 and 4x4 bubble butt.
I think he is well on his way to a little paded room with no view.
Forrest,
Your going to need a pressure washer. ;)
Ron,
Padded room won't work for fletcher. He will eat the padding. Best to string him up in a diaper style bungy from the ceiling. :-laf
