Engine/Transmission (1994 - 1998) 14 cm hsg?????
2nd Gen Non-Engine/Transmission Service contracts
2nd Gen Non-Engine/Transmission Which shock is better? Rancho or Bilstein
Is there anyway to tell if you have a 14 cm non-wastegated turbo housing on the motor???????
Numbers or something??????/
Thanks, kevin :)
Well... . I guess the first thing that would give it away... . is the lack of a wastegate. Other than that I do not know of any casting numbers that will tell you.
Come on guys... . someone should know!
Josh
Look into the throat of the housing(input side) the numbers cast in there are the size. I. E. 12,14,16 cm2. If it has been modified(quick spooled)then it could be a little bigger than the number. please correct me if I'm wrong
