Received my 14 CM non-gated housing last week from Piers.
Finally found the time to install it today. What a difference.
No lag at all, instant power. Install was fairly straight forward
except for the exhaust side on the turbo housing. It extends
about an 1 and 1/2 inches further than the stock unit . Managed
to massage the exhaust back on with some Gorrilla bars. Still
enough clearance on the firewall but, will add some aluminzed
insulation nonethess later on. I decided not to crank up the
power as I will add some Lucas Injectors in a few weeks.
Boost is running a few pounds higher at cruise, 55-60 was
normally about 1 In. and now it is 3-4 inches boost. Smoke
does not appear to be worse unless I get on it, will work on that
later as well. While on the intake added an AFE filter and
drilled and tapped the exhaust for the pyro. EGT runs about
500-600 at cruise.
500-600 at cruise.
