You will never regret going to the 16". I lost another 15" tire on one of my landscape trailers this morning right after I dropped off a tractor. Harvey talked me in to buying my newest equipment trailer with 16" wheels and I couldn't be happier with the choice. Not a single tire issue on that trailer and it sees a lot of use
jeepit,
Massive discussion on Airforums.com about switching to 16's from 15's and many opting from Michelin. I did the same this spring after some GYM issues and the constant failure reports on ST tires.
Two wheel mfgr's seemed to be the go to companies. Sendel and Hi Spec. I chose Hi Spec and Michelins with a Dill TPMS thrown in. Discount Tire was able to provide all on one invoice. I did the mounting.
You'll need to figure out your wheel size and specs. Does any wheel have a wheel mfgr part number on it that you can research and then look at the options?
These are Hi Spec and Michelin's.
Gary
The LTX M&S and M&S2 are not the best choice for a trailer tire. To much siping and outer rib has gaps in it. The siping will cause tread squirm and the broken outer rib grips to much in tigh manuevers. The XPS Rib is a much better LT trailer tire or the Bridgestone Duravis R250. Snoking
