Engine/Transmission (1998.5 - 2002) 1693 code help
okay trying to help old Vet friend his 99 3500 auto. thrown 1693 vtec companion code. no other code my smarty cleared it. but truck has power to the dash and only clicks once trying to start. are the 1600 codes ecm related. I dont have my manual with me but on a 99 were is the pcm I want to see if its dirty. truck is parked hooked up to a boat that I just got done backing up and turned truck off. unhooked boat went to pull away and wont start. how can I find out what the other code would be. my smarty wont tell me. where should I start. batteries unhook maybe??
thanks.
2002 HO 6-SPD LB 4X4 QC HTT 62/14 SB-DD3600 TST PM3/*REVO-BETA*SMARTY MACH 4'S, RINGED AND STUDS, AFE/2:eek: " FTE 6" STACK D/PRICOL GAUGES, FASS 150, VULCAN 1/2 DRAW-STRAW, 3/8 FUEL LINE, DSS-BOX DT PRO-FAB TRAC BAR, CONV-T STYLE STEERING,DUNKS TRACTION BARS, AIR BAGS,17'' KMC BLACK HOSS, 315/70/17 MICKTHOM MTZ'S 6" RCD LONG ARM LIFT. :-laf... THANKS RIP Source Automotive Performance Diesel - Offline
The 1693 code in the ECM says there is a code in the other module (PCM). PCM has little to do with starting other than maybe being in P or N. PCM is on the firewall behind the air cleaner.
Starter contacts?
What is battery voltage reading when you hit the starter?
I have a 2002 pretty modified. I do know I have good fuel pressure. DTT trany. I got the 1693 and it suddenly shutoff. Got it restarted. Drove for about another 1/2 hour shutoff again, 1693 code, would not restart.
I need some ideas of where to start hunting and possible things to look for.
So, is the dealer the only one who can scan the corresponding 1693 code? Mine has set this code 10 times in the last month. Still runs good tho.
Every time we have run across that code it has been ECU replacement time. If the 1693 was set in the ECM thats the code and means the ECM has issues. You will need a reader capable of digging deeper into the DTC's.
