16cm housing
DOOR panels on a '91?
Newbie
Hi guys: Today I,d install the 16cm2 housing . It really wasn,t what I. m expected but I already
bought anyway, and also took me about 2 horas to change it was easy. I just drove 10 miles
empty, may be when I pull the trailer I really notes the different.
93 dodge 3/4 ton auto K&N ,PW injectors, 16cm2 housing.
If you decide to upgrade to a 14 or 12, I will buy it from you for Mom's 92. Email me if you do that. puckett@semo.net It is a bit sluggish with a big load, and smokes a little. I figure a 16 ought to clean it up and add a little zip. I plan to buy one anyway in a few weeks, after a few paydays.
Daniel
My 16cm2 housing didn't blow me away at first either. Small perceived increase in acceleration. Changed from an 18cm2.
However, the turbo lag was reduced noticably, that was huge while towing. Getting the load moving is much nicer.
The biggest thing I got out of this was that my tweaked pump settings were no longer generating black smoke. That meant boost was there sooner, and went up. So I got to add more fuel. You will definately notice that one!
Finally, the torque curve seems longer and flatter. Big while towing. Makes sense too if the turbo spool up is faster, the curve will look better.
1992 2wd 16cm2 k&n straightpipe pump tweaked 3 ways pw-injectors.
jon
Hey Julio, sorry to hear that the turbine didn't wake it up more. Maybe you need to pull with it first like norby said to see if you notice a difference. I'm at a loss as to what the problem is. Like Cody said at the last meeting, you may need to have your pump looked at, but by who I don't know. It's a shame that in a city as big as Houston we can't find someone who knows more than just the basics about these pumps and their settings. Good luck.
92 Ext. Cab, Auto trans. , 3. 54 Non-LS, Isspro Tach, 16 cm housing, PW injectors, no name 3 Gauge cluster, 230,000+ miles, straight pipe, old and abused but still running strong!!!!
Guys,
I think alot of people notice mediocre improvements with the 16 cm housings. The reason alot of folks run them ove rhte 14cm wastegate housings is because they're cheap (the housings, not the purchasers). The 14 is a little more expensive, but it is the way to go. The 14 cm houisngs on these trucks have great lowend performance, but if you have 4. 10 gears and are going to "high speed" the engine, the 16 is the way to go. Let meknow if you need either. I run the 14 and love them, I just changed my 99 to a 14 also. The 12 is too small for much power gains witohut heat. Please email me if you think you need a different housing.
thanks
Don
Ol' Blue "First of the first gens: 1989 D 250 Ice blue met. 5 spd 3. 54, 155,000, Banks stage III powerpack, 3. 5" straight exhaust, pump adjustments, "'Ol Blue Special" injectors.
1999 3500 4x4 Chassis cab Emerald green ISB 5 spd 4. 10 K&N Filter straight exhaust 9 ft flatbed WARN fenderflares,Let, 275hp injectors installed, boost and pyro gages, VA plug'n power and Practical Solutions boost module. Jacobs E brake. Getting ready to install Banks Power Pack TLC!!
May buy another one in 2009!!
Check us out at:
http://donstractorrepair. homestead.com
