Originally posted by nascar mark
Guys, it is easier to remove on the truck. Use some wooden or plastic wedges between (stagger ) turbo and housing. Beat evenly. Works everytime. 2 of the bolts are easier to remove if you can lossen turbo alittle from housing and rotate the turbo to give you more room. As far as the intake ,it can be rotated were ever you like at any time by lossening the outer housing/back plate and spinning into position.
Replace bolts if damaged with stainless and never seize.
Hope this helps.
