16CM2 Turbo Housing
Don't laugh, but is there a pickup mounted backhoe??
Gear splitters ,O/Ds. Questions for all.
Where is the best place to get a 16CM2 housing? Best Price? I want to save some money and get it Jet coated before installing it.
The exhaust is going to have to be moved forward some or is there an adaptor?
Dee'sel
97 2500 Club 4X4 3. 54, Forrest Green/Driftwood, LSD 5 speed, K&N Air filter RE0880 & Psychotty, TST #11 all the way forward, #12 for winter, AFC spring kit, Geno's Exhaust Blanket, TST EGT gauge & TST 0-60 boost gauge in A Pillar, Hypo clutch ass. , Cat-be-gone, 4" Dynomax Bullet muffler, Crome 4" turn down, AmsOil ser 2000 75W-90 in Trans, Geno's trans filter kit, AmsOil ATF In Transfer case, AmsOil 15W-40 Oil W/ Bypass system, AmsOil Ser 2000 75W-90 in front & Rear ends, Lund Winter front, Leer Cab Level Shell Driftwood , 235/85R16 Goodyears, Dyno'd 342 HP *NRA/USPSA member and proud of it*
[This message has been edited by drawson (edited 08-21-2000). ]
You could also check with some of the performance shops for used ones. Us folks are ALWAYS upgrading something. #ad
Give TST a call.
Mick2500
I have one with 1k miles on it from my 97. I tried e-mailing you but I don't know if it went thru. If your still interested,try e-mailing me. Craig
C Schomer, Why did you remove the 16cm? I have my egt pretty much under control now, but have considered trying a 16 anyway.
95 2500,std cab,4x4,auto by Dunrite,TST #4,AFC spring kit,Pier's gov spring kit, timing @ 15*, 215 injectors, Walker muff, 3. 54,Diprocol gauges in cupholder slot, K&N,Optima reds, Valentine One radar deflector,Diamond utility bed, custom 52 gal aux tank under bed.
I have a 16cm2 laying in the garage. I have been thinking about installing it but, I read a post on this forum by someone who claims they only help at upper rpm, say around 2500 rpm. I am usually towing around 2000-2100 rpm. and do not want to mess up the responsiveness [did I spell that correctly?] of the turbo.
Paul A. Schmidt
95, 4X4, SLT 2500, 5 spd. , 4. 10, 270 hp. ,675ft. lb. TST, AFC spring kit,215hp. injectors, Pacbrake, Walker muffler,
GearVendor O. D. , CenterForce Dual Friction clutch.
Eastern PA.
Duke,I started driving my truck for a daily commuter - I like it so much better than my work car(94 grand am). I'll save the 94 for winter. I'm in town a lot now and just like the 14 better for that. Don't get me wrong,the 16 is dynamite and I wouldn't discourage anyone from using it. Even with the 14 (and towing),I constantly have to slow down for the weeny cars on all the hills and no PSD will come close to it. I know, I'm sick - I'm happy with less power! FYI,on my test hill(towing),the 16 was 2mph faster than the 14 with no other changes. If you want max power,you want the 16.
Drawson, If you decide you want a 14, let me know. Mike
92 Std cab. LE. 215 P-pump reman cummins motor. 5-speed, 3. 54, 105 gal Aux tank in bed. Borgeson shaft, Banks Power pack. 12cm Hot end housing w/wastegate. 4" Exh, Pyro & boost guage, oil temp guage. E-brake. Galaxy DX99V, Used as a Hotshot/express Reg. at 36,000 lbs in 48 states. http://hometown. aol.com/hotshothauler/myhomepage/business.html
C Schomer, As a seat of the pants guess,at what rpm would you think the 16 starts to equal the 12? I'm putting out enough torque that even with a converter and trans work I don,t use full throttle with the converter locked at less than about 1800 rpm.
Pier"s gov spring kit has made a big diff in the way the truck performs. I now have about 20 mph more useable speed in third gear for passing, so I can shift into OD at a higher rpm and be a little easier on the lockup clutches.
Piers gov spring + 12v pump = Scourge pump. #ad
Money Sink - 96, 5 speed, Injectors, 280/685 & AFC housing slid.
4" CAT back & CATless, 4" chrome turn down straight out back.
ISSPRO Pillar, Delvac 1 & Amsiol, K&N, Monicas silencer ring removed, Exhaust brake, Mag-Hytec, 3:54, 235s.
HX35s days are numbered, HX40-16 is here.
Un-Bombed = Boring
[This message has been edited by Forrest (edited 08-24-2000). ]
I went from a 12 to a 16 on my 24valve at Bruce Mallinson's recommendation to reduce EGT's. I'm stage 3 at 350HP. The 12cm housing has too much back pressure for a heavily fueled 24 valve. The 12valve engine does not breathe as well and needs more boost to overcome the internal back pressure. Consequently a 14cm housing would be fine. 12valves will not benefit from larger housings unless the compressor is changed to HX40 for more boost and 4" exhaust is used along with ported heads. 12valves run 10 pounds more boost than 24valves at the same HP levels, unless porting is done. I used to be at 31Lbs all the time with the 12 and now get more HP at 27Lbs with the 16. Throttle response change was not noticeable. Torque curve on the dyno is similar but more of it.
EGT's dropped 200 degs. Too much housing will damage low RPM power.
Jay Bennett
Jay Bennett http://home. pacbell.net/jaybo
Duke, I haven't had the 12 for so long I don't remember. The 16 doesn't help much around 2k rpm, in fact the engine sounds doggy but above 2500 the 16 was a very noticeable difference. The 24v autos have the HY35. Can anyone tell me if the 24v manuals have the HX35?? If they do I might keep this 16 for a later date. Craig
What are the pros and cons of moving the stock torque plate forward and a 16 housing on a 95 5spd
95 3500 diesel cab & chasie 5spd 4x4, 97 3500 diesel Ccab 5spd 4x4, 97 ", 98 Qcab ", 2001 3500 diesel Qcab 6spd 4x4
