fuel solonoid
I will check today. Bought one three or four years ago for 72 dollars at the Bosch repair shop. I think you are being held up. I will find out a current price.
1stgen4evr
James
EDIT By the way, you can take the plunger out of the body and the truck will run. you will have to use the manual cut off lever (raise the hood etc, very inconvienent) but you are not dead on the rail as to using the truck. You could run a pull cable to the inside. You will have to custom bend a wrench to get the solonoid body out. The bracket on the back of the pump is in the way and you can remove it permanently or bend it down to get to the solonoid. I bent mine with a large adjustable. You will have to purge the fuel system before the engine will run as you let air into the pump when changing the solonoid.
