I'm still trying to figure out which thermostat is better to use.
I talked to Cummins today and did some searches and have come to the following conclusions:
1. 99 Dodge trucks came from the factory with 180* thermostats.
2. 2000 and up trucks came from the factory with 190* for emission reasons.
3. Cummins recommends 180* thermostat for their motors used in non Dodge applications.
4. Our ECM need to see 165* in order to consider the engine to be fully warmed up.
5. Cummins will not "recommend" a 180* thermostat because it would affect emissions and they don't want to get in trouble with the EPA.
6. Timing advance only happens when the temperature is like 40* or below.
Can someone with more knowledge confirm or dispute the comments above.
I installed a 180* thermostat in my 2000 truck and it seems to have more power, but does not seem to be as smooth running.
Also, any chance I'll be getting more cylinder washdown with a 180* thermostat? Will the Dodge ECM actually notice a 10 degree temperature difference?
Thanks in advance,
Charles
Thanks in advance,
Charles
