Originally posted by nickleinonen
nope. the 245's are 245mm tread width and the 265's are 265mm tread width. so the difference is 20mm, but the overall height of the tires are different. the 245/70/19. 5 tire is ±33" tall, while the 265/70/17 is ±32" tall. now if you put a 285/70/17 tire on the stock rims, you would have a tire that is the same height as the 245/70/19. 5 being ±33" tall, but being 40mm wider
just a refresher for anyone who has forgoten [or never learned] what the numbers in a tire size are. example below...
Thanks for the education. I knew part of this stuff, obviously, but never learned the other because it wasn't necessary. No need to clog the brain with information it doesn't need. Now that there is a need to know, I can learn it.
I want a taller tire - preferably in a commercial size - to drop the rpms 200-300, but do NOT want a wider tire. Wider tires throw more mud and snow on the vehicle and aren't as efficient because they pack snow instead of digging down to where there is traction.
Of course, DC could have solved this issue for us if they'd left the 3. 55 rear end ratio as an option for owners who do lots of highway driving.
205/75/15
the red 205 is the tread width in millimeters [mm]
the green 75 is the aspect ratio. the tire's sidewall on this example is 75% of the tread width which works out to 153. 75mm [per side]
the blue 15 is the rim size in inches
there is other stuff that is on tire sidewalls like P and LT which are ratings for passenger and light truck. the ply rating is there too [c=6, d=8, e=10... ] and speed ratings [a-z more or less in alpha order -lower letter, lower speed, higher letter, higher speed rating ->y or w being fastest (z is below them)] and there is also temprature and traction ratings, with AA being top and C being lowest [AA, A, B, C]
