I've seen several photos recently of member's 4WD trucks with Rickson or other 19. 5" wheels and tires. Curiously, I have not seen any 2WD trucks using them. Does anyone know . . . do 19. 5" wheels and tires fit 2WD trucks also. I may be mistaken but it appears that 2WD trucks have slightly less clearance in the fender wells and 19. 5" tires and wheel seem to fill the fender wells with little reserve clearance.
A set of six 19. 5s is very expensive and I don't really need them for weight capacity but I was tossing around the idea of installing a set if and when I buy a new 3rd Gen later this year or early next year. The taller tires would provide a little taller final drive ratio to compensate for the lower ratios in the G56 six speed.
Klenger: Have you run the numbers for a Gen III G56 3. 73 19. 5" truck in your handy final drive formula?
Harvey
Harvey
