figured out how to make the f250 box work, just trim the corners off the plastic fan blade. the front crossmember is fabricated and the motor is permanently mounted. the 1" body spacer made room to move the motor back about 2-3 inches, which made room for the radiator. looks like the '97 Powerstroke intercooler will fit perfectly around the radiator, just have to cut holes in the radiator support. I'll have to trim the back of the grill and relocate the hood latch to make room for the intercooler.
i bought a new TPS from Dodge, which I can mount anywhere. The hydro-boost from the CUCV fit nicely, only had to cut off the top 2" of the bracket (which was useless anyways) and drill two holes in the firewall.
i sprayed the firewall with three coats of Quietcar. it dries a dark gray and looks similar to bedliner. its soft and scratches/mars easily. i'm going to spray the hood, inner fenders, floor and roof with it later.
Still have to fabricate a transfer case crossmember and hang it from the frame. I bought 1410 yokes and u-joints for all the axles and the transfer case from Off Road Design in Colorado. I'm buying a 14 bolt with a locker and disc brakes from a buddy. as soon as it's all in, i can measure for the driveshafts.
will post more pics soon.
