Well, I am still rounding up the parts needed to convert my 1992 D250 to the 47RH transmission.
I have located most everything except the transmission itself. The 47RH is somewhat hard to find either used or as a core. I don't want a rebuilt transmission as I am going to build one up myself.
I have access to a 4WD 47RH but still need a 47RH 2WD overdrive section. I know that the intermediate shaft from the main section into the overdrive unit is different, but that is no problem.
I need to know if the later 47RE overdrive units will work on the 47RH main transmission section. The 47RE overdrive units are much easier to find. If they will work, what years if not all years will work?
Thanks in advance for helping!!!
