pwerwagn
Hey guys, first time posting here in 1st gen forum. I read here alot though.
My brother in law bought a nice 1993 ex cab, 4wd, auto truck recently. had a new trans (auto), and some other nice stuff. This is the first 1st gen I have had the pleasure of working on. I love the first gens by the way... I have 2 70's dodges.
Back on track... .
What it has done as of now:
190 injectors (he is thinking now of selling the 190's and doing POD's)
aftermarket intercooler
HX35 with 12cm housing (wastegated) from a 98 I had laying around
full 3", mandrel bends, decent 3" muffler
BHAF
Yesterday we finally messed with the pump a little. It ran ok before, didnt smoke at all. the 12cm housing is nice, he didnt like the 16 on it. It was making almost 30 psi with the 12cm before pump mods.
anyways, we turned the fuel pin about 90* or so CW. The tick mark on his wasnt at the 12:00 position, it was about 11:00. we put it about 2:00 or so.
I also turned the "smoke screw" in about 2 turns to start with. And I loosened the preload on the AFC spring with the starwheel as far as it would go.
We went and drove it ("Fuel screw" still untouched) and there was relatively no diff. still making 30psi. I plugged the wastegate so I would know if it was making more, and not wastegating itself.
so, with the fuel screw untouched, it had like 10% more smoke, relatively none. and it would clear up immediatley.
So I turned the smoke screw in another turn or 2, thinking that maybe the boost line was leaking going to the AFC. it didnt make any noticeable diff again!!!
so we turned the fuel screw in about 2 turns, and adjusted the idle back down. It runs ok now, it will put out a puff of smoke that is somewhat black, but it clears up totally within about 1-2 seconds. and it only does it from a dead stop, pedal to the floor run.
So, Im used to P7100's and tons of smoke. Im not sure if this is normal for the 1st gen, or whats going on. I still think the AFC might not be seeing boost, cause the power is very linear. It never "hits" like mine does when the afc moves.
Is the AFC line leaking common?? I checked it decent (didnt pressurize the intake yet though looking for leaks, thinking you guys may have a suggestion).
Oh yeah, boost is up slightly meaning more fuel, max is now about 34psi or so.
any info is appreciated,
thanks,
Jeff
Back on track... .
BHAF
thanks,
Jeff
