Engine/Transmission (1994 - 1998) 1995 12 valve, tach zero, no cruise, no charge, no a/c, runs perfect otherwise
Engine/Transmission (1998.5 - 2002) Innova 3150 Code Scanner
Engine/Transmission (1998.5 - 2002) rough running (help)
Stacy
Hello all,
I have a 1995 12 valve with a 115k miles on it and a manual transmission. Coming home from a road trip in Idaho the other day it started acting up in that my tachometer dropped to zero, my cruise kicked off, the alternator stopped charging, the a/c compressor kicked off, and yet the truck ran fine. It did this intermittantly off and on throughout the trip.
I'm sure this has been discussed in the past but I thought I would throw it out there for some feedback. Thanks for any advice you can provide!!
IIRC when the A/C is affected along with tach and the other things you mentioned the Engine Speed sensor is losing it's ground. Try running a seperate ground to it.
