Engine/Transmission (1994 - 1998) 1996 - Brakes, but no PS
2nd Gen Non-Engine/Transmission AC Question - High Pressure Hose
Engine/Transmission (1998.5 - 2002) Fuel Pressure Gauge Noise
The power steering went out on my '96, but the brakes still work. The problem started when we replaced the seal between the vac and ps pumps due to a leak. CAD doesn't engage either.
What should we be looking at replacing - the vac pump or the powersteering pump? I'm not familiar with these vacuum-assist systems. Thanks.
Chris
On a 96, the brakes are vacuum assist, so the vacuum pump is working. Make sure you did not lose or damage coupler as ps pump drives off the vac pump.
