1998 gauges
My dead pedal cure
In park it still moves
Lost my gauges I have had this happen before so I knew where to to start found the splice on the right hand side of engine was not making contact so I fixed that it wasn’t even soldered just looked like it was held together with some type of epoxy after I cut the factory heat shrink away also I’m not sure if the little ground wire ten gauge is factory or not but replaced tfat and everything is good as new again
