1St Gen Body Parts
Extended oil change on '93 with 5.9 Cummins
log on issue / website trouble
I'm working on a 92 W350 extended cab and the floors are shot! Anyone know of a place to get good quality replacement floor pans?
JC Whitney has universal ones , how ever some time this spring maybe LMC there might be a web site called vintage power waggon parts
Get some flat steel and make your own, that's what I did for my 77 power wagon, if you have a cut off wheel and a welder its not that hard to do.
I believe they are available. Trying to think where I saw it.
When I get back in the house I will check.
Please Standby....
Depending upon how bad your floor boards are . You could use fiber glass cloth and and put that in the floor , ive done that to a 73 i have that had some pitting with small holes and its sill going strong today and that was 20 years ago
Take a good look at the cab mounts, and the inner rocker panels as well, if the floor is bad there is a good chance they will be bad too
BSchwarzli, have I ever said, "You rock!" to you? 'Cause you do.... I've been looking as I know my '93 will need a driver pan this summer when I pull the mat and fix the hole I had for the NV4500 swap correctly..... Nobody has 'em in stock or have any idea when they'll be available..... Thanks for the link!! :D
The headliner material sticks to a glossed cardboard shell. The shell is held up by the trim. Behind that is metal surface and without that liner the interior of the truck is super loud!! I know from experience. Lol
You will need to pull the sagging liner off it, using a brush scrape the old foam and glue off till smooth cardboard again, spray with super sticky gorilla booger type glue and roll new headliner material onto it.
Will take about 3 hours total. Cost about $100. Easist woth 2 people. Have done mine 2x in 11 years. Mostly cause I didn't clean all the remnants off the first time. ;):-laf
Google auto headliner kits and you will find many sites offering the kits in your color complete with glue.
Id do it if the rest of my 92 would warrenty it its pretty well beat to hell. i need a new cab and box or some thing that needs a new heart !!!!!
IF you like it enough any thing can be fixed, I put new floors, cab corners, and inner and outer rocker panels on a 77 power wagon.
