1st Gen won't start
1 st gen air filter houseing ideas
Dash Light Brightness...
Hi all,
93 D350 Cummins/5 speed won't start. Started it at the store, drove four blocks and parked in front of the house. When I went to run another errand, it didn't start. Turn the key, lights go to 'start mode' but nothing, no click or stutter or anything. It acts like the clutch interlock isn't engaging, but I don't know where the switch is located. Could it be anything else?
Later,
Joe
The clutch saftey switch is under the dash, up from the pedal aways, and is pretty hard to get to but it is possible. I unhooked my switch and crimped the two wires together so I can start my truck from the ground, ie not in the cab. Other than telling you were the switch is at I can't help you with your problem as mine has yet to do that. Good luck
