I know there's been lots posted about the first oil change, but thought I would add my experience. The filter was on *****-tight, but 4 busted knuckles later I got it off. The drain plug was easy getting off; I replaced it with one of those easy-drain nipple plugs with the lever to open. I've had the same lever-actuated drain plug on my other two Dodge Cummins, so I thought I'd continue the tradition.
Used a Fleetguard LF16035 filter and 12 quarts of the Chevron Delo LE 15w40 for the refill. I've used Chevron Delo for quite a few years in my other CTDs as well as several Kubota tractors with never an ill result.
I changed the oil exactly 1 day shy of six months since I bought the truck new in March 2016. The odometer reading was 9,905 miles with 6,400 miles of that towing my 14K 5th.
Comments?
Comments?
