OK, This is my first diesel.
1993 1 ton, 4wd, positrack rear end, 3:55 gears. 5 speed.
Black. Some rust under cab. Will fix at body shop.
91k orig miles
It has a mechanical fuel pump on the engine side, (You can pump it manually too) and then it has a purge thing.
If I run it out of fuel, is that hard to fix?
Put Rotella, and Wix filter on it. K&N filter will be on it soon.
What kinds of fluid go in the rear, and front differential?
I want to change ALL the gear box fluids. I have no manual.
Any basic instruction for a 1st time owner?
What's "Getrag" mean about the transmission?
Thanx
Nate
91k orig miles
Thanx
Nate
