2 "B" motors in offshore boat?
How to fit it in
4BT timing, how much?
I am guessing you would have to find a dealer that sell marine gas turbine engines and they should know a mechanic who would service them. There is a company that is putting out a Rotary Diesel engines that puts out 500 hp and weights 350 pounds. If you are going to high hp in cummins go to the C series it is designed for it. As far as outdrives go look up Konrad they make an excellent outdrive that can handle the torque the diesels put out. I am not sure Mercury makes a good drive that will stand up to the diesels. I have seen 6 or so Charter boats try the Mercury outdrives and everyone has switched to Konrad drives. The different boats had Bravo III's and Bravo II drives. I do not know of any of the gas power boats that had problems just diesels. I have a new set of Bravo III drives that are powered by 5. 0 gas engines at 260 HP. I am going to put it in the water next week and I hope that they work out. The new gas set up for twins cost $25K. Any way good luck with your project.
This is a cool thread, I don't know how I missed it. :D Think of the trans in the #6 as an over-built Powerglide. It basically has a high and low range and as Kieth said can be geared to what ever you like. Figureing that out would require more brain power than I have. :cool:
If I remember correctly, I think Kieth may have been a tad low on the price of the #6's. I could be wrong but I remember more along the lines of mid 40's for one... ... :eek: :eek:
If you get it going let us know. That would be on bad ride.
P. S. If your buddie is truly loaded, have him check with Hustler Powerboats in New York I think. Douglas Skater also does exotic motor installs. Both of these guys will do WHATEVER the customer can afford.....
If you can get a crate marine 370 - fully set up for $12,000 - take it. That's a great price
Yes... that would be a steal.
I repowered a single engine boat 3 years ago with a new 270 hp marine Cummins... I shopped pretty hard and fianlly paid 15,400 for the engine and transmission (transmission was about 2400).
A friend repowered over the winter with the same package and cost went up to $17,500.
There is a company in Texas that puts together a marine conversion kit for a truck engine... since you're planning on BOMBing the motors this might be a better option, also much cheaper. You can either buy the whole kit or buy "ala carte" and only get the things you need like the exhaust manifold... .
If you BOMB a new 15,000 engine you will void the warantee.
Good luck on your project. . sounds like fun!
