2 cummins 6bt rebuildable cores
2005 Dodge Ram 2500 4x4 SLT Regular Cab
GDP AirBoss Intake Plenum
i have 2 cummins recon 12 valve engines that i will sell as rebuilders, 1 has low compression on 2 cylinders, the other has low compression on 4 cylinders, they were industrial engines with p pumps (p3000) water to air intercoolers, and hx35 turbo's, the engines will be sold as assebled block and head, injectors, with timing cover and gears, full valvetrain and an exhaust manifold. one has an oil pan and the other comes with a dented dodge pan. both engines turn over and tried to start when i had them in the trucks just werent hitting on all cylinders. $550 each both have the crank sensor hole in the back of the block if needed to convert to a 24 valve engine.
i also have 2 air to water intercoolers that come with injection lines, and grid heaters. $200 each
2 p3000 injection pumps with fuel shutoff solenoids remanned by cummins recon around 2004, $350 each
1 air compressor with hydraulic pump $200, compressor without hydraulic pump $150
allison 545 trans core (pan is crushed) sold as a core $300
may have other parts i have to check, all prices are plus shipping
Im looking for front timing covers , do you have any for sale or Air to Air intercoolers ? , i might be intersted in a air to water
