Im wanting to install the coil spring spacers. I have heard alot of talk about the track bar needing to be replaced or extended. What is some of yall's input on the track bar situation. After a new track bar is put in, do you still need to get your truck alligned??
Also, with the two inch lift in the front, will I be able to run 33 x 14. 50 x 16 super swamper boggers or even just the 33 x 12. 50 x 16 boggers with 16x10 inch wheels without them rubbing? I know that i will be able to run regular 33's on 16x10 inch wheels without them rubbing but i was just wondering about swampers.
I would appreciate pic's of 2 inch level kits installed if you have them available
Will McComas
Will McComas
