Thanks for the help guys, I have other things keeping me from working on the truck right now,
In a day or two I'll wrench on it some.
A little more info, I have not had the pump, lines, injectors or anything else off of truck.
It just started running rough , so I changed the fuel filter- found some grit and a little water in filter, at that point I cleaned the pre-filter and then pulled the fuel tank and cleaned it.
put it all together and still runs the same, pumping alot of continuous air out of front injector line and 4th one back.
Keep those ideas coming ! I am trying to stay away from replacing injector pump,
If possible !!!
KB
