2" Leveling
P/S Problem
Saw this hood scoop - thought I'd share
Made the mistake of installing Tuff Country 2" leveling kit. Other than D25's, any good suggestions on coils and stocks to replace the kit? I sure don't want to tear up my ball joints!
KORE has a 2" kit with springs, new bumpers and shocks and 2" stabilizer bar drop blocks. This is an expensive solution, but when I get more money that is what I am going to do.
I had the Superlift and it works ok if you never leave the street. If you do go off-road or work in a construction site I would highly recommend that you go with Kores system. My superlift coils were showing signs of over compression with just 4000 miles on my truck. Plus my one of my bump stops was MIA and the other was 1/2 worn out. Also if you pull trailers then the superlift will reduce the GVW of your truck. just my $. 02
