There are two ways to do this that I would consider proper: a lock out hub conversion (contact Dynatrac for this as they build one of axle assemblies and parts better than OEM and will outlast OEM). They other way is to install 2WL in the transfer case. I personally have a 2004 jeep wrangler (same driveline set up as dodge just slightly smaller) That I have installed half ton components in after years back. One of the things I did do was install a 2WL kit in it and several other wranglers cherokees grand cherokees and even my moms durango with 5. 9L V8. You could also install this in the dodge rams with 231 transfer case. I would reccomend this option whenever we did a slip yoke eliminator on a transfer case cuz is was so jeep and helped so much on the trail and on the street and plenty other instances. But anyways I just bought a 2004. 5 dodge ram 3500 with cummuns When ever I want to use low range I have to run front axle too. This causes bind that stretches the transfer case chain and causes deflection in the case that could "pop" the case in two big chucks held together by a chain. I personally wish to install 2WL cause you never know when you'll need it and when you have it you find so many more instances that it is handy such as in 1-2 mph traffic for miles 2WL 1st gear and no brakes or accellerator needed and you can pick up a magazine to catch up on reading.
To those of you out there who are wondering why do you ever need to use 4wd low range: by taking a transmission such as an automatic and install a second transmission behind it that is manual and shifting the 2nd transmission into reduction range you are taking the pressure off the 1st transmission and making the torque converter run cooler. Taking the pressure off an automatic transmission is useful because I have seen first hand just rebuild transmissions come back to the shop because the owner backed up a heavy camper and puked out alot of fluid because they didn't take the strain off the transmission while the entire drivetrain was in a bind cuz the wheel couldn't spin or roll very well while backing up the camper.
Installing lockout hubs is not the best of idea if you don't need them cuz then you have to get out and engage them before you go in the mud, snow, beach, pond, field, or bad place to be driving. then you trail the mud in the truck and have to clean the truck. Its just so much easier if the driver can stay in his seat and drive (definition: operate controls to go somewhere) from the inside instead of having one of the driver controls outside of the truck.
