2nd Gen Non-Engine/Transmission 2000 Chimes/Intermittent Wipers
Engine/Transmission (1998.5 - 2002) Broken crank?
2nd Gen Non-Engine/Transmission Toyo MT's ordered.
Do the 2000 models have chimes for door open & headlights on? Also my intermittent wipers are not intermitting. Is there a fuse or relay or what? Any help or ideas appreciated.
I would think your model would have the headlight on chime, but don't know for certain. As for the windshield wiper not being intermittent, it's usually the switch assembly that needs replaced. Sometimes you can get away with taking it apart and cleaning it though. When I had to replace the switch assembly it was around $65.
FWIW..... on my 98 I wanted to kill the door chime. I found the noise came from a little box under the dash, so I unplugged it. No harm, I thought, I had done that on an older car and it worked.
Well, on the truck, that did kill the door chime (and headlight on), but the box must be more than a noise maker, as it also killed the delay wipers.
