Engine/Transmission (1998.5 - 2002) 2000 dodge 2500
Engine/Transmission (1998.5 - 2002) Bob V 2WD low kit instructions
Engine/Transmission (1998.5 - 2002) Charging issue
Hi everyone sorry for the silly question but I have a 2000 Dodge Cummins auto with 250000 miles I just bought put a exhaust and intake in it . It ran perfect installed a Fass system on it 2 days ago while priming after the first bump the pump kicked in and started it’s cycle check engine light came on ! second time it didn’t cycle and wait to start light didn’t come on tryed a few more times and pump wouldent come on waited a while and wait to start came on and pump came on primes it bled it and started right up but I have a p1689 code it starts right up and throttle response is good I haven’t driven it yet but should I clear code and hope for best or is it prob gonna have a issue ? Thank you for your time
Trent, welcome to the TDR; you have come to the right place in addressing issues with the 2nd gen trucks. I suggest you post a truck profile listing the mods' to your truck which will help the TDR Gurus' in deciphering the problem. You say that you have a P1689 DTC, which if my memory serves, is a communication failure from the ECM to the VP44. If the truck will start and run normal I would clear the code and drive it. If there is a problem, it will come back.
Good luck...gregg
2000 dodge 2500 auto trans 4x4 extra cab short bed edge intake and diamond eye 4”exhaust
