2000 model sneeze when turned off
Walker Airsep
Sticking Power Door Locks
i usually hang out in the first gen forum see signature. I drove my dad's 2000 24 valve 3/4 ton 4x4 with auto trans in it. The truck only has about 10k miles on it now. I noticed that everytime you turn off the engine it makes a sound similar to sneezing. i asked my dad about it and he was told by the dealer that this is perfactly normal. Anyone had this problem, if so what is the cause of it.
93 D250 5sp 3. 54 gears sans muffler, ISSPRO tach, K&N filter, needs to be bombed BAD
I would rather be cummin than stroken
Mine does the same thing. Doesnt bother me but what is it?
2001 2500,AUTO QC,4x4,SWB,SLT PLUS W/LEATHER,HEATED SEATS,PWR ON BOTH,4:10 LSD,PERFORMER IAS, WARN,MAG-HYTEC DC&TRANS DD,TRUCK TRUNK BOX,KC,RED VALVE COVER,PATRIOT BLUE W/AGATE INT.
Mine has done it for 22,000 miles. Love the sound. it announces a real truck has arrived. From previous threads on this site, I believe it is caused by the engine stopping quicker than the serpentine belt. In other words, it's a belt "sneeze. "
Y2K 2500 4X4 LB QC Auto Trans
The "sneeze" you are referring to is indeed the "chirp" that most people refer it as. It will happen especially when the silicon fluid is hot in the fan clutch to force more fan lockup, when the motor stops the fan wants to keep going. You can eliminate this by putting on a Goodyear Gatorback serpentine belt.
icarus
'98. 5, 2500, 4x4, LB, QC, AUTO, 3. 54 rear, Snugtop, Rhinoliner, ISB, non Cummins enhanced ECM, DDIIIa injectors, Transgo Diesel shift kit, KJones TC, Rancho 9000's, Autometer boost, transmission temp, digital pyro, Mag-Hytec diff/transmission cvrs. , Redline lubed.
My 2001 has never had the belt chirp. In fact, most if the manual-transmission trucks I have driven do not have the chirp. The automatics on the other hand, do.
I love to shut the truck off when there are a group of people around, First they look because of the engine noise, and then the chirp really makes them look, sounds like a motor seizing I think.
Y2K01. 5 3500 SLT Quad Cab 4x2, Bright White, Camel Tan Cloth Interior
Y2K Four Winns 170LS Bowrider, 4. 3 V6 Volvo Penta
1999 Suzuki Intruder 800 (for sale) e-mail me if interested, only 1500 mi
Yeah!!! I'm kinda diggin' it too... Got a Gatorback sittin' under my front seat, but can't quite change it out #ad
2001 Quad,4x4,AT,4. 10LS,LB,Loaded enough,stock,mostly... . 65 Chevelle sedan, Hella nice driver, 53 Nash Rambler Convt,1 of 653 built,[not a Metro], GM drivetrain, injection, and auto/od
Specialized FSR PRO Stumpjumper,Cannondale F2000, Loaded
MTD Lawn tractor with flames Cummins ISB
12' fishin' boat, loaded. .
Mine is a 95 auto and I have the thing... when its just a slight squeek its kinda cool... but most of the time its very loud and its kinda embarrasing at times. . Jim
1995, 2500, 4x4, 3. 54, auto,130,000 miles, custom fuel plate, boost and EGT gauges, 215 HP injectors, RE-0880, custom 4" from down pipe.
Yep my 01. 5 does the same chirp. I believe in the owner manual it says this is normal???? My buddies 96 does it also. Both trucks are auto if it indeed makes a difference.
