2001.5 Fuel rate on injection pump
Looking for boost module recommendations
inop ignition key light
On another thread, someone said that there is a max fuel rate for the eth/dee. Is this so and can I bypass it. My 2001. 5 seems to flatten out in 5th and 6th gear. It runs like a scalded dog in the lower four. Would upgrading fuel components do the trick? I want, no, NEED more Power!!!.
2001 3500 QC 4X4 Cummins H. O. & 6 Speed, Powermax 2 and needing more power!!!!
Not sure what the rate of flow is. A weeks pay if not more depending on what you buy can cure that problem. Have you looked into injectors? Thats the first fuel enhancement I would look into. After that an electronic fueling box is nice to kick on and off when needed on those stoplight to stoplight surges.
If you just go with a box, your still limiting the amount of fuel that could be getting into the combustion chamber, so the big bad box isnt doing any real justice yet.
Beware. More fuel in means more air in is needed and if more air is going in, you need to get more out. Exspensive isnt it.
Always ready to help!
2000 2500 Red Sport quad cab, 4x4, K&N, DDI's, straight piped, boost, pyro and fuel pressure gages, Hot Power Edge, mean looking set of 33. 5" tires, Snap On diamond tool box, Marine Corps window sticker, Semper Fi!
1972 340 Cuda'. Original tripple Black, 340 car w/air. Good clean car, super stock springs, Weld Prostars, shaker hood, strong 340 with a 727/4000 stahl, 4. 56... . Bombs away!
NRA Life Member. http://www.geocities.com/chadsheets
