What I believe is a problem I'm having is it seems like the front brakes do most of the stopping which is normal with quite a bit of pressure on the brake pedal, but when I check the back disc brakes they still have a lot of pad left. I had my fronts done at about 60000 and the truck has over 100000 now. I would think the rear brakes should be worn more. I do haul trailers so I figure the rear rakes should have more wear. Any ideas or do you believe this is normal. Thanks......
