I'm glad to see you guys with the newer trucks aren't having any trans problems to speak of.
The '94s and (I think) some early '95s had problems. It seems the lube flow to the O/D unit wasn't sufficient. This means that towing well under the load limit at speeds encountered in the western US would overheat the O/D. I was told by a friend that owns a trans shop that the parts would look like someone took a torch to them.
Also, it took several thousand miles for this to appear. The problem was remedied and if anyone has, or knows someone who has an older truck, there is a simple repair to prevent it but the trans must be completely disassembled to do it.
