2001 bad turbo, anybody else?
Oil Filter
Warning From DC About Remote Starters
My truck has 11,000 miles on it. While getting a vb, tc, ez box, Pac Brake, and Smart Box installed last week at DTT, Bill Kondolay showed me that every blade of the turbo was chewed. Just curious if anyone else has had this problem? Fortunately it's under warranty. Still, I feel pretty lucky that no metal sucked into the motor. Also, just in case there's somebody out there (like me) who hasn't bothered to take off the stock air filter for a looksee... . nuf said.
I checked mine when I replaced the front shocks at 7,000 - no problem. If I remember correctly there was another post a few months ago with the same subject. I would demand a replacement if it were my truck. Those blades spin incredibly fast so any imbalance is not good imo.
2001 HO 6 speed Regular Cab SLT 4x4 3. 54 anti spin 2500. Used for the daily grind and sneaking away to some secret Baja beaches toting a cabover
If your turbo compressor blades are chewed or
damaged by foreign objects that were injested through your air cleaner,you will
probably be denied warranty. Foreign object
damage is not a turbo fault. The turbo mfg.
will void it,but if you are lucky maybe DC will accept it.
I got lucky, the dealership is going to warranty it. My truck has the smaller turbo. The 2001 1/2 trucks have the bigger one. No Chrysler folks are not fessing up if in fact there is a problem with the smaller ones, but there must've been? I tried to get them to give me a bigger turbo, even if it means paying a little more for it but they wouldn't.
It's possible that part of the original casting broke off even before it was delivered to the dealership. I'm just glad they're taking care of it.
Chris, are you saying that your blades are chewed also? Is our truck a 2001? How many miles? Hopefully, the dealership won't give you any hassles. The one that I went to is Larson Dodge in Puyallup, WA. They did not question how it happened at all. They had to order the new turbo. It took a week to get it fixed, but they set me up with a loaner vehicle at their cost.
Sig, mine too is a 2001. 5 ETC with the crappy small turbo. I sent you an e-mail to get your phone number to talk more about it and if you had any hassels. Get a hold of me if you would. Chris
If the blades are chewed up, what happened to the metal it spit out???????
Might be worth MAKING them do a compression check on all cylinders. Find out what is normal before accepting their answer as good enough. Good luck.
Always ready to help!
2000 2500 Red Sport quad cab, 4x4, K&N, DDI's, straight piped, boost, pyro and fuel pressure gages, Hot Power Edge, EZ box, mean looking set of 33. 5" tires, Snap On diamond tool box, Marine Corps window sticker, Semper Fi!
1972 340 Cuda'. Original tripple Black, 340 car w/air. Good clean car, super stock springs, Weld Prostars, shaker hood, strong 340 with a 727/4000 stahl, 4. 56... . Bombs away!
NRA Life Member
My Diesel Page
Chris, I sent you an e-mail. Look forward to hearing from you.
Chad, thanks, that's a good idea. I have not received my paperwork from Dodge(computer was down)for whatever work they did. I'll check with them tomorrow to see if they did a compression check, if not, I'll get it done.
Sig,
You may want to ask for a new CAC as well. It could be harboring some shrapnel. Would check the hoses as well to make sure they are clean.
Dave D
2001. 5 QC LB 4x4 Auto 3. 54 Everything but Leather, Bright Silver Metalic, ARE K Series, Diprocal EGT, Boost and transmission Temp in an Autometer Dash Pod, Westin CPS Platinum Step Bars - Black on Stainless
I think it stands for Cold Air Charger.
The intercooler.
'97 Jeep TJ - Tons of stuff.
2001. 5 BR3500 Chassis Cab 4x4 163"wb - ETH/DEE, SLT, K&N in stock airbox, autometer boost/pyro, GTS clear headlight covers, no bed (yet). .
I agree with the above. The dealer needs to pull the intercooler and clean it out to make sure no metal is left in there which can later be sucked into the engine (if it already has not). Also do not forget to have all the charged air hoses, etc. cleaned. Don't know if they will do the compression test but I would make a point of your concern of turbo fin metal having been sucked into the engine and if need file a report with DC. This could be one of those cases where no appearent damage is noticable now, but later down the road it could show up as needing a premature engine rebuild after the warranty has expired.
Any insight on what caused the problem in the first place? What was the turbo shaft's lateral and end play, or did they check? Could the bearings of been bad and caused the blades to rub the compressor housing?
How do you tell if you have the large or small turbo?
2001. 5 2500 4X4, QC, Auto, 3. 54 LSD, SLT, SWB, Trailer, Camper & Snow plow Packages, White, 35k# Cody Hitch, 20' Gooseneck Lowboy flat-bed Trailer.
Not to be picky, but I believe CAC stands for charge air cooler.
'01 2500 QC LB 2WD 6sp HO SLT+ leather 3. 54 ltd slp BLACK trailer tow and the all important cab lights. (for hauling motorcycles)
95 Freightliner FLD132 70" Condo 470 Detroit 13spd 3. 36 (to pay for motorcycles)
89 H-D FXRS, 99 Triumph 955i, 86 Suzuki GSXR750 ltd, 00 Aprillia SL1000
98 Yamaha YZF-R1(race), 95 Kawasaki ZX7(race)
Looks like I get to join the club. Went out to inspect my turbo this morning and discovered that the tips of the blades on my compressor wheel have been making contact with the housing. There are very faint but discernable marks on the housing as well as the tips/edges of a couple of blades. My truck just turned 11,500 miles.
Couldn't find any pieces of aluminum, I will be checking the hoses later this afternoon. This must be a feature of the new and improved HY35.
The Cummins tech line told me it shouldn't be a major problem if caught early. The tiny pieces of aluminum, if they make it past the Charge Air Cooler, should blow through the motor and would be unlikely to cause damage to pistons, cylinder walls or valves.
Now I get to have the pleasure of dealing with the DC warranty/service people. Should be very interesting.
Just got off the phone with a nearby Dodge dealer, they said they had one in December and DC (STAR) authorized a new engine. I'll believe that when I see one. I am going to drop my truck off on Thursday so they can inspect the turbo and go from there.
Dave D
2001. 5 QC, LB, 4x4, Auto, 3. 54, Everything but Leather, Bright Silver Metallic, ARE K Series, Diprocal EGT, Boost and transmission Temp in an Autometer Dash Pod, Westin CPS Platinum Step Bars - Black on Stainless
Dave D, sorry to hear that you're part of the club. I'm definately interested in what you find out. I'm going to discuss with the Dodge dealership again and take it from there. I still haven't gotten my paperwork back for the new turbo install, but I don't believe they checked anything else.
Hopefully, if I was successful today in creating my signature, it should provide a picture link to show turbo damage.
2001 2500, QC, 4X2, SLT, 24 valve, ISB, A/T, Tow Pkg, Bright White Clear Coat
DTT VB, TQ, Smart Box, PacBrake, PowerEdge EZ Box, Bosch 275 Injectors, AutoMeter Triple Pillar,Isspro Gauges Pyro/Trans/Boost, Trans Cooler, Avitol Alarm, OEM Roof Lights, OEM Fog Lights, Flip/Tow Mirrors, Ram Polished 3rd Brake Light, Eyebrows, Pace Edwards Rolltop, Toro Bed Liner, Carr Super Hoop/Deluxe HoopII Steps, Husky Front/Rear Mats
1998 33. 5' Hitchiker Discovery Triple Slide 5th Wheel.
http://albums.photopoint.com/j/AlbumIndex?u=1512392&a=11425526
