Well I tried to get by without resorting to 911 - truck is dead in my driveway and holiday season does not allow for the most time to stay and work on it and I need to get it running soon.
Truck is a 2001. 5 6-speed with a Edge Comp without the injection pump tap. I did tap it previously and had issues with losing connection and have now soldered the original wire together. Died while driving it - almost like running out of fuel (checked that). It will crank, but will not fire. It had done the same thing when the injection pump wire became disconnected earlier - reconnected it and fired right up. Now codes 1694 and 1693 are active (also had 1689 and 0237 previously but may or may not be related). The "wait to start" light is acting flaky - sometimes doesn't light at all (35* weather), sometimes for a second or two, sometimes flashes while cranking. The tach and oil pressure also seem a bit flaky as they will sometimes stay at 1100 RPM/50 psi when releasing the key to the run position after cranking but not starting. I cleaned all of the terminals on the grid heater/relays and also the ECM, PCM, and injection pump connectors. Also removed and cleaned IAT sensor. Lift pump initially appeared to be working, but has since stopped. It does not come on with the key or after the starter is bumped. I just jumped it with 12 volts and it does operate. I jumped the injection pump pins 6 and 7 and the truck started and idled perfectly (this may have been while the lift pump WAS operating. ) I changed the filter and now may have introduced air into the system. Brand new batteries and I cleaned the terminals when they were installed and used protectant spray on them. Cleaned the ground connections, except the ECM and PCM ground connectors at the passenger side battery (couldn't get either one apart).
About 2 years ago I had a "no bus" signal on the odometer and lost all dash functions (but no other symptoms) 2 or 3 times, but not since.
I'm leaning towards ECM as the cause, but am looking for other causes or ways to further verify ECM. I will try to trace the lift pump wiring to make sure it is OK. Thanks for any more input.
See previous thread: initial post hopefully I remembered all of the details.
