Here’s the update.
I checked the LP first thing this morning by cracking the fuel in-port banjo bolt which is how the shop manual says to purge the LP side of air. I got no flow at all in the 2 seconds of run time. I tried it a couple of times, then listened to the pump with a Harbor Freight stethoscope. It was running, but didn’t sound good at all. Lots of rattling inside and it sounded like it was just spinning free. So, I drained the fuel from the filter canister and decided to change it out. I mean with 140K on that LP, and all I’ve learned on here from all you guys, I decided it was just time anyway and the best place to start. The new pump sounded lots stronger with the stethoscope and I was able to easily bleed the low pressure side and had pretty good fuel flow. I don’t have a gauge yet, but I felt good about the flow I was seeing so I tried to start her up but it wouldn’t fire up at all. The next step was to bleed the HP side at the injectors. With the engine turning over, I did get air out of the first injector, then fuel, but no startup yet. I went to the second one and got air, then fuel and she fired right up and ran like new. I went ahead and cracked 1 more just in case. I didn't get much air at all and it ran smooth. Money is tight, so I bought a stock replacement Precision LP (made in USA) from Oreillys, since they are located about a half mile from my house, and put it back in the stock location. If I have to do it again, I’ll probably move it to the frame. I’m crossing my fingers and hoping the VM keeps on doing its thing and wasn't damaged. Oriellys sells one but it’s $1600.00 tax included. My next project is to install a simple gauge so I can keep watch on the LP from here on out, or maybe the light that Mwilson mentioned above (thanks Mwilson for all the info and suggestions!!) . I never pull much anymore since I retired, a 17 ft aluminum boat and a 4 wheeler, so I’m hoping this pump works out.
Thanks again to everyone that helped me with this. It’s not a hard job at all and I’m sure if I have to do it again, I’ll be able to do it in half the time. I did pull the starter this time, as the manual says, and it’s good I did as it turns out since the shop that replaced the last one for me didn't have one of the bolts very tight at all and the power cable was much too loose. This is another reason I’d rather do anything I can myself, then I know it's done right. I’m thinking it can be done pretty easily from top-side though without this. I put the new LP back on from the top by laying a moving blanket on top of the engine. It was pretty comfy too. LOL.
Maybe next time I can help someone else out!
Randall
Edited because I forgot to say the price of the Precision LP pump. it was $159 + tax. I was glad it was made in USA!
Randall
