I have bled lines 1, 3, 44, and 5 all three times. It still tries, but does not carry itself.
Gordon,
Just so I'm clear about what's happening... are you saying the engine sounds like it's just about to start running while being cranked, but as soon as the starter is released it doesn't continue running?
I used a scanner to clear the codes and it is not setting any codes at all.
Perfect.
If the VP44 was not getting a voltage, would it even try?
It shouldn't. The VP44 must have power to provide any injection pressure. No fuel (i. e. : no injection) means the engine won't run.
Questions (please don't read anything into these... I'm only trying to make sure I understand the big picture and verify what I think I remember about your situation):
1. This remanufactured VP44... where did you get it?
2. Has the engine ever run using this remanufactured VP44, or did you install it after the engine wouldn't start due to the ECM problem?
3. Did you install the remanufactured VP44 or did someone else do the work?
4. Are you sure the correct VP44 pump shaft key-way was used, and was it installed in the correct orientation?
5. You haven't done anything to the fuel injectors or connecting tubes... correct?
6. Were any other maintenance, repair, or modifications done to *anything* before or since this whole problem started besides the aftermarket lift pump, a remanufactured VP44, and a "refurbished" ECM. Am I missing anything?
As you know, your diesel engine only needs fuel and air to run. Presumably it's getting an adequate amount of air (I don't think you messed around with the air intake or exhaust system), so that only leaves fuel delivery as the culprit. So at this point it may be worth verifying the VP44 is actually getting power when the ignition key is on. It's worth pointing out you should be getting a trouble code from the ECM saying it can't communicate with the VP44 if the VP44 isn't getting power, but it can't hurt to check anyway. To do this, simply disconnect the VP44 wiring harness connector, turn the ignition key ON, and use your test light to check that voltage is present between sockets 6 and 7 of the connector. Since the ECM should report lost communications with the VP44 when you turn the ignition key on with the VP44 disconnected, you'll likely need to clear some trouble codes after doing this test.
Next, I'd recommend carefully hot wiring the VP44 and then try starting the engine again. With as much fuel injection line purging as you've done, it probably isn't necessary to do that again unless the engine just won't start. If the engine still won't start even with the VP44 hot wired and another injection line purging, then I'd suggest there's something wrong with the remanufactured VP44 or the way it's been installed and you'll have to work from there. If the engine does start with the VP44 hot wired, then you can probably assume the ECM is at fault.
Hang in there and please keep us posted!
John L.
