Details here: TDR Privileges
The horsepower rating of your Cummins Engine will be stated on the "data plate" along with manufacture date, firing order, fuel rate and Engine serial number, which is located on the aluminum gear housing (driver side, behind belt, under throttle area).
If its a 2002 Model Year, it should be a 235hp/460 ft lb (unless its a 6 speed HHP 245/505ft lb).
I have always wondered if the early 2001 (without disk brakes) has the 235hp that was advertised for the 2001 model. I know my 2001 (which has disk brakes) states it has 235hp.
I think the 2000 Model had both 215,and 235hp in the auto's. I have an early 2000,its a 215hp,a friend has a late 2000,im almost positive its a 235hp auto. Ill have to check his plate.
The 235hp/automatic truck for the 2000 model year did not exsist in the US. If you go back and look at the chart on Fritz's site,you'll see they forgot to list the 2000 manual engine and listed the 2000 automatic engine twice... obviously a print mistake.
Jblock,
I'm assuming you have a 2000? You'll need the EZ for the 98-2000 engine *and* you'll need the flat datalink plug adapter for the 2000-2001 engine.
Regarding horsepower, did they make any internal changes when upping the hsp. , or is it all done with the pump ecm, etc. ??Did they change anything in the trans. ,etc. If it's all external mods, who cares , just add an EZ or puck or whatever and you have better than what the factory put out?? Besides, it drives you crazy with the early this, late that, 2000, late, early 2001, jeez!!!
