Details here: TDR Privileges
I would think it's the same as the 2001. The dodge 4X4 trucks have been straight axles for years. If you have the Dana 60 it should have a vacuum canister on the back side of the axle towards the Passenger side. It should have two vacuum hoses going to it. Take a look at it and reply back.
Two helpful hints:
1. use the search button at the top of the page to search for your questions... Most have already been discussed numerus times and you can get needed information Fast.
SORRY FOR CAPS. THIS IS 2002 WITH A COMPLETELY STRAIGHT AXLE NO AXLE DISCONNECT PERIOD,VACUNE ETC,MY 2000 AND 99 BOTH HAVE THE DISCONNECT THE 2002 DOES NOT
My 02 3/4 ton has the vac. disconnect on the front diff. Good or bad, dont know. For what this truck will be used for prabably good. She's not my digger. ----Proflow
does everyones 2002 have the disconnect,this was built end of january. 2500 hd 4x4 long bed quad cab. it has a reverse cut axle with no disconnect,just looking for others since all my 3 other trucks had one. :--)
thank you dodge torque wagon for the info,just what i was wandering. the 2002 solid axle tracks and steers 100 percent better than my 2000. both are exactly the same trucks. will be talking to a friend at dynatrac about some hubs. this system when complete will be years ahead oy my current front axle. thanks again john
I went and looked at the dealer and it seemed that trucks built after January did not have the CAD. I tried to get some info on this and all the salesperson wanted is me to do was drive the truck. I went back to the shop and asked them if they knew anything. There "ACE" Tec didn't know what a CAD was. I had to take him out and show him.
As you could from the other thread my truck doesn't have the CAD. I e-mailed Dynatrac but didn't get a response from them. I will try again another day. Jeff
