This is incorrect information.
Read
THIS ARTICLE on the Blue Chip Diesl website for some good information on lift pump pressures.
John L.
Nothing on that link says anything contrary to what I said.
What they said is 5psi provides enough lubrication for the lift pump at maximum power, however 15psi provides enough return fuel to the tank to cool the pump/electronics. At 5psi, you're not getting the return fuel and you're not getting the cooling.
Please don't tell people they'll be fine with 5psi, as they're going to cook their injection pump and electronics. The numbers I stated are extremely conservative SAFE numbers.
Blue Chip goes on to say that the best solution (in their eyes) is for a factory location (block mount) pump that flows at least 15 psi. I don't agree. They say that it's up and away from road salt (versus a frame mount) and they say that the in-tank pump is the worst. I don't agree with that either. They suggest that heat on the electronics is what kills their lift pumps, then turn around and suggest putting the lift pump back in the hottest place possible. The OE lift pump failed because it was a poor design and the heat and vibration of being block mounted kills them. In tank pumps have the best cooling. They're up in New Hampshire, so I guess road salt is an issue for them, and the trade-off may be worth it. The rest of the country, not in the salt belt or NE, doesn't really have to worry as much about salt corrosion, and getting the electronics off the engine works great.
So go ahead, run 5psi on your truck and see how long it lasts. I've seen a lot of conflicting information - at one point it was said that Dodge doesn't provide a pressure spec, only volume over time. It's hard to measure volume while you're driving down the road, so keeping an eye on pressure is a good way to stay safe.
In doing more searching, someone posted info from the factory service manual stating 10psi minimum while running and 7psi while cranking. Of course, there is always planned obsolescence to think about - if they can spec 10psi and make it last until just after warranty then they gain customer pay work.
Either way, it's a far cry above 5psi.
